When it comes to selecting the perfect key switch, there is a multitude of different options for you to choose from. To make this process easier for you, here at Overclockers UK we’ve compiled all of our expert knowledge about mechanical key switches into one article.
We’ll be showing you all the different types of key switches from Cherry MX, Glorious, and Ducky, along with some of our favourite mechanical gaming keyboards!
![How to Choose the Perfect Key Switches](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/HowtoChooseKeySwitches-BlogSquare-1024x1024.png)
What is a Mechanical Key Switch?
Without a key switch, you wouldn’t be able to type or engage in your favourite boss battles. Every mechanical keyboard consists of keys that utilise a switch mechanism. This is generally constructed from a spring, stem, and some type of housing.
What are The Different Types of Key Switches?
There are four different types of key switches you can choose from. Each has its own use and unique set of characteristics.
- Linear
- Tactile
- Clicky
- Low Profile
Linear:
These key switches typically don’t feature an audible click or bump. When pressed linear switches have a smooth feel and are extremely light. Linear key switches are ideal for fast typists and gamers, especially fans of FPS titles. The lack of tactile feedback allows for ultra-fast keypresses and better reaction times when you need them most.
Linear switches also don’t make any audible noise when pressed.
Tactile:
Tactile key switches are characterised by the distinct bump you feel when pressed. Since you don’t have to press the key all the way down for it to be registered, tactile key switches are perfect for typists and those who work from home.
Tactile switches won’t make an audible click.
Clicky:
Clicky key switches are similar to tactile switches. They have the same bumpy feel but make a distinct clicky noise when pressed. If you prefer silent typing, then clicky key switches aren’t for you!
Low Profile:
Low profile switches are shorter and instead of sitting inside the casing, these switches are on top of the body of the keyboard. The pre-travel on low profile key switches is much shorter compared to the other types, making them more ergonomic and comfortable to use.
Along with the type of key switch, there are two other crucial factors you need to consider when selecting the perfect key switch. These are:
- Actuation force
- Pre-travel
Actuation force:
Actuation force is the amount of pressure required to register which key you are pressing.
Pre-travel:
Pre-travel is how far down you need to press the switch before it registers.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/CherryMX-logo-300x300.jpeg)
Cherry MX Key Switches
Cherry MX Switches are one of the most popular key switch brands. Each key switch has been designed with a specific function in mind, such as precision or speed.
Switch Type | Force | Pre-travel | Noise | |
MX Red | Linear | 45cN | 2.0mm | No click |
MX Black | Linear | 60cN | 2.0mm | No click |
MX Speed Silver | Linear | 45cN | 1.2mm | No click |
MX Brown | Tactile | 55cN | 2.0mm | Click |
MX Blue | Clicky | 60cN | 2.2mm | Click |
MX Green | Tactile | 80cN | 2.2mm | Click |
MX Clear | Tactile | 65cN | 2.0mm | No click |
MX Grey | Tactile | 80cN | 2.0mm | No click |
MX ULP Click | Tactile | 65cN | 0.8mm | Click |
MX Silent Red | Linear | 45cN | 1.9mm | No click |
MX Silent Black | Linear | 60cN | 1.9mm | No click |
MX Low Profile Red | Low profile | 45cN | 1.2mm | No click |
MX Low Profile Speed | Low profile | 45cN | 1.0mm | No click |
MX2A Red | Linear | 30cN | 2.0mm | No click |
MX2A Black | Linear | 30cN | 2.0mm | No click |
MX2A Speed Silver | Linear | 30cN | 1.2mm | No click |
MX2A Brown | Tactile | 30cN | 2.0mm | No click |
MX2A Blue | Clicky | 25cN | 2.2mm | Click |
MX2A Silent Red | Linear | 30cN | 1.9mm | No click |
![Cherry MX Switches Explained: Everything You Need to Know!](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/09/CHERRY-MX-300x300.jpg)
Looking for even more helpful advice and information about Cherry MX key switches? Check out our ‘Cherry MX Key Switches Explained’ blog post for more.
Glorious Key Switches
You can also purchase key switches from Glorious. Designed to work with their range of barebones and modular keyboards, the key switches utilise high-quality materials to deliver the best possible performance.
![Glorious Logo](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/Glorious-Logo-300x253.jpg)
Glorious key switches are available either lubed or without. If you opt for the lubricated variant, then the switches have been primed for an extremely smooth typing experience. Whereas, if you wish to customise and specifically tailor your key switches to suit you, you can select them to come without and apply the lubricant yourself. To aid you with this, Glorious even have their own dedicated lubing station.
Panda | Tactile | 67g | 2.0mm | Click |
Lynx | Linear | 60g | 2.0mm | Click |
Fox | Linear | 45g | 2.0mm | Click |
Raptor | Clicky | 55g | 1.8mm | Click |
Gateron Brown | Tactile | 45g | 2.0mm | No click |
Gateron Black | Linear | 50g | 2.0mm | No click |
Gateron Blue | Tactile | 55g | 2.3mm | Click |
Gateron White | Linear | 35g | 2.0mm | No click |
Gateron Green | Tactile | 80g | 2.3mm | Click |
Kalih Speed Bronze | Tactile | 40g | 1.1mm | Click |
Kalih Speed Copper | Tactile | 30g | 1.1mm | No click |
Kalih Speed Silver | Linear | 27g | 1.3mm | No click |
Kalih Box Brown | Tactile | 50g | 1.8mm | Click |
Kalih Box Black | Linear | 60g | 1.8mm | No click |
Kalih Box Red | Linear | 45g | 1.8mm | No click |
Kalih Box White | Tactile | 50g | 1.8mm | Click |
Kalih Purple Pro | Tactile | 50g | 1.7mm | No click |
Still struggling to find the perfect Glorious key switches for your keyboard? Our ‘Glorious Switches Explained’ blog post has plenty more helpful advice and top picks just for you.
![Glorious Switches Explained: Know Your Panda From Your Raptor](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/glorious-switches-300x300.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/Ducky-logo.png)
Ducky
Ducky key switches have been designed to work seamlessly with your mechanical keyboard, boasting popular models from both Cherry MX and Glorious.
Cherry MX Red RGB | Linear | 45gf | 4.0mm | No click |
Cherry MX RGB Silent Red | Linear | 45gf | 3.7mm | No click |
Cherry MX RGB Speed Silver | Linear | 45gf | 3.4mm | No click |
Cherry MX RGB Brown | Tactile | 55gf | 4.0mm | No click |
Cherry MX RGB Blue | Tactile | 60gf | 4.0mm | Click |
Cherry MX RGB Black | Linear | 60gf | 4.0mm | No click |
Kalih Box Navy | Clicky | 60-90gf | 3.5mm | Click |
Kalih Box White | Clicky | 55gf | 3.6mm | Click |
Kalih Box Brown | Tactile | 45gf | 3.6mm | Click |
Kalih Box Red | Linear | 45gf | 3.6mm | No click |
Kalih Box Super V2 Speed Silver | Linear | 40gf | 3.5mm | No click |
Kalih Box Jade | Clicky | 50-60gf | 3.6mm | Click |
Kalih Box Jellyfish Y | Linear | 50gf | 3.6mm | No click |
Kalih Midnight Pro | Linear | 45gf | 4.0mm | No click |
Kalih Polia | Tactile | 60-67gf | 3.88mm | Click |
Gateron G Pro Yellow | Linear | 50gf | 4.0mm | No click |
Gateron G Pro White | Linear | 38gf | 4.0mm | No click |
In need of a closer look at Ducky key switches? Check out our ‘Ducky Switches Explained’ article for more!
![Ducky Switch Kits Explained](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/ducky-switches-square-300x300.png)
Our Favourite Mechanical Keyboards
If you want to upgrade your battle station with a brand-new mechanical keyboard, then we’ve selected some of our favourites down below. These keyboards are either barebones or hot-swappable, meaning you can switch between different key switches to find the ones that suit you!
Glorious GMMK Pro 75% Barebones Keyboard
Completely barebones, with the Glorious 75% GMMK Pro you can truly create the keyboard of your dreams. With its 5-pin hot-swappable PCB, you can select from numerous different types of key switches and keycaps to optimise your typing experience. All of the tools you need to switch between them are included with this keyboard.
Along with this, this barebones keyboard has been constructed with an aluminium top frame for enhanced durability. For an added dramatic touch, it also includes per-key and side RGB backlighting which can customise with the 18 different pre-set lighting effects.
![Glorious GMMK 2 65 Keyboard Barebone ISO-Layout - Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/glorious-gmmk-2-pro-65-barebone-keyboard-300x300.jpg)
- Mechanical gaming keyboard
- Completely barebones
- ANSI layout
- Key switches and keycaps not included
- 5-pin hot-swappable PCB
- Per-key and side RGB backlighting
Ducky One3 Matcha USB Full-Sized Mechanical Keyboard
Built with brand-new QUACK mechanics, this Ducky One3 keyboard comes armed with everything you need to defeat your enemies. Thanks to its hot-swappable PCB, you can choose between a plethora of different key switches to find the one that suits you best! As standard, however, this keyboard comes with Cherry MX Clear key switches. For enhanced durability, this keyboard is armed with true PBT double-shot keycaps in a stylish mix of pastel green and cream.
- Full sized mechanical keyboard
- QUACKY mechanics
- Hot-swappable PCB
- PBT double-shot keycaps
- This model comes with Cherry MX Speed Silver key switches
- Stylish pastel green and cream design
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/Ducky_Matcha-300x231.png)
Ducky ProjectD Tinker 75% RGB USB Mechanical Gaming Keyboard
Enjoy the best of both worlds with the Ducky ProjectD Tinker 75% Mechanical Keyboard. This pre-built keyboard boasts a hot-swappable PCB allowing you to freely customise your key switches to ensure it perfectly suits your individual demands. PBT double-shot keycaps ensure superior durability that stands the test of battle, along with superior precision. Finally, the RGB backlight will make this keyboard a stunning addition to any set-up, granting you the ability to customise the lighting to suit your aesthetic.
![Ducky Project D Tinker 75% RGB USB Mechanical Gaming Keyboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/ducky-projectd-tinker75-pre-built-keyboard-removebg-preview-300x300.png)
- 75% form factor
- ISO layout
- Hot-swappable PCB layer
- RGB backlighting
Ducky Zero 6108 Wireless Black Mechanical Gaming Keyboard
Enjoy minimal cable clutter and responsive typing with the Ducky Zero 6108 Wireless Gaming Keyboard. This full-sized keyboard features tri-mode connectivity, allowing you to choose from 2.4GHz, Bluetooth, or even wired, to suit both your preferences and individual demands. Premium sound dampening materials ensure near-zero operation, whilst the PBT double-shot keycaps stand strong against general wear and tear.
- Full-sized form factor
- Wireless
- Tri-mode connectivity
- Hot-swappable PCB
![Ducky Zero 6108 Wireless Keyboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/ducky-zero-6108-keyboard-black-300x300.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/06/OCUK-Academy-Square-300x300.jpg)
Overclockers UK Academy
Our dedicated Overclockers UK Academy is packed full of in-depth videos and guides all about the wonderful world of PC hardware and peripherals.
You can find a detailed blog article all about building a mechanical keyboard, which also covers the various types of key switches.
What Switches Did You Choose?
What key switches did you choose and why? Let us know in the comments below!
